Axial flux motor design
Posted 01.09.2015, 02:57 GMT-4 Low-Frequency Electromagnetics 2 Replies
Hi Guys,
I am working on the design of an axial flux motor in 3d in comsol RMM module in ACDC module. Can anyone suggest me how to define the coil of a motor in the RMM module. I am able to use the multi-turn coil feature in simple Magnetic field physics. But when i try to do the same in RMM physics, the study shows error.
I have already designed the full geometry of the motor and tested the same in Magnetic field physics, and the model in working fine including the multi-turn coil function.
But i want to do the same in RMM physics as well, to visualize the rotation of the rotor caused by time dependent magnetic field generated by the col current.
Any help is welcome.
Also, if someone has model for a multi-turn coil in RMM physics, can you share with me.
Thank You
Thank You
2 Replies Last Post 15.03.2016, 09:33 GMT-4
