What does operator : mean in COMSOL equations?
I found this operator in equation views of poroelastic material model which is showing at the attached picture. It seems that the operator ' : ' connects two tensor (C and epsilon). But the tensor 'C' has 6 rows and 6 columns while the tensor 'epsilon' has 3 rows and 3 columns. It doesn't seem to be a common multiplication.
1 Reply Last Post 11.05.2015, 08:41 GMT-4
Posted: 10 years ago 11.05.2015, 08:41 GMT-4
strain (epsilon) and stress (s) are symmetric 3x3 tensors. Basically elasticity (C) is tensor of rank 4
and dimensions 3x3x3x3. Since this is to complicated visualise many people use the following transformation. Due to symmetry stress and strain have only 6 independent values that can be written as a 6-dimensional vector. Only then C appears to be a (symmetric) 6x6 matrix (with 21 independent values).
Hence you can read the colon as the multipliateon of a rank-4-tensor with a rank-2-tensor resulting
in a rank-2-tensor. Or, as a matrix-vector-product in six dimensions.
Hope that make it clear
Regards
Jens
Hi, strain (epsilon) and stress (s) are symmetric 3x3 tensors. Basically elasticity (C) is tensor of rank 4 and dimensions 3x3x3x3. Since this is to complicated visualise many people use the following transformation. Due to symmetry stress and strain have only 6 independent values that can be written as a 6-dimensional vector. Only then C appears to be a (symmetric) 6x6 matrix (with 21 independent values). Hence you can read the colon as the multipliateon of a rank-4-tensor with a rank-2-tensor resulting in a rank-2-tensor. Or, as a matrix-vector-product in six dimensions. Hope that make it clear Regards Jens
