COMSOL could model all kinds of radiation source? black body radiation?
COMSOL's training engineer claimed that COMSOL could model all kinds of radiation source on the boundary.
But when it goes to the black body radiation, it looks like not so easy.
in the concentrated solar or thermal PV area, the lighting source is the sun or a high temperature back body radiator, it is a continuity wavelength and all solid angle radiation. and the simulation with these high luminous intensity should consider all the rays at the same time.
could COMOSL, as a professional multi-couple software, model a black radiator and how?
thank you for any suggestions and help.
2 Replies Last Post 16.07.2010, 06:57 GMT-4
Posted: 1 decade ago 16.07.2010, 05:58 GMT-4
radiative exchange is always "difficult" because you must get all related view factors and mutual echange factors correct. For simple geoemtry this is possible, by using the coupling integration variable, but for more complex geoemtries it becomes tedious. I do not know of any "simple" software for radiative exchange.
But for simple geoemtries COMSOl is OK and does the job, and easier than others. See the doc
Hi radiative exchange is always "difficult" because you must get all related view factors and mutual echange factors correct. For simple geoemtry this is possible, by using the coupling integration variable, but for more complex geoemtries it becomes tedious. I do not know of any "simple" software for radiative exchange. But for simple geoemtries COMSOl is OK and does the job, and easier than others. See the doc Good luck Ivar
Posted: 1 decade ago 16.07.2010, 06:57 GMT-4
assuming a (diffuse) black or gray body radiation is the "simplest" form of thermal radiation. No special wavelength or angle depdending stuff is required because the spectrum is defined by the black body radiation and the dependence of direction can be derived from lambertian beam pattern (cosine law).
I think, COMSOL can handle this, but only if you purchase the heat transfer module ...
Using this module, COMSOL provides calculation of the view factors by direct integration (no attention to shadows) or by the hemicube method (some kind of ray tracing -> with shadowing).
However, I hope COMSOL handles black body radiation correctly, because i'm using it right now :)
Hi, assuming a (diffuse) black or gray body radiation is the "simplest" form of thermal radiation. No special wavelength or angle depdending stuff is required because the spectrum is defined by the black body radiation and the dependence of direction can be derived from lambertian beam pattern (cosine law). I think, COMSOL can handle this, but only if you purchase the heat transfer module ... Using this module, COMSOL provides calculation of the view factors by direct integration (no attention to shadows) or by the hemicube method (some kind of ray tracing -> with shadowing). However, I hope COMSOL handles black body radiation correctly, because i'm using it right now :)
