solving two partial differential equations nonlinear in comsol?
I want to solve two pde nonlinear with two variables (please find in the attachment file) with the constants.
For solve, i tried to use the heat equation and PDE (c) in two step:
step 1: solve PDE(c) only
step 2: solve two equations with the step 1 results
Unfortunately, the results weren't changed anything if i change the constants.
Are you see this problem?
3 Replies Last Post 05.04.2017, 20:12 GMT-4
Posted: 1 decade ago 03.04.2015, 17:11 GMT-4
I am wondering "Density" and "Heat Capacity at constant pressure" of "Heat Transfer in Solids 1" could be any non zero values.
I am wondering "Density" and "Heat Capacity at constant pressure" of "Heat Transfer in Solids 1" could be any non zero values. Regards,
Posted: 1 decade ago 03.04.2015, 18:52 GMT-4
Thanks for your attention, @myungwu woo. Because this is the stationary case, so these values doesn't impact in the solution. Best regards,
Posted: 8 years ago 05.04.2017, 20:12 GMT-4
As I am new to comsol I want to ask a question about the simulation you did. Why did you use steps in the solver? I know that without this I can not get any solution but how should I know that I need to put steps to get the solution.
As I am new to comsol I want to ask a question about the simulation you did. Why did you use steps in the solver? I know that without this I can not get any solution but how should I know that I need to put steps to get the solution. Thanks
