coupled nonlinear odes: bvp
can i solve my own model of coupled nonlinear odes (bvp)
5 Replies Last Post 29.01.2013, 02:45 GMT-5
Posted: 1 decade ago 02.06.2010, 07:51 GMT-4
You can solve ODE's in Comsol. In Comsol 3.5a look at the global equations under physics menu. There are very nice examples in the documentation on how to do it.
Posted: 1 decade ago 28.01.2013, 02:49 GMT-5
can i solve the attached model
Posted: 1 decade ago 28.01.2013, 06:54 GMT-5
you need to reexpress your model to fit into the parameters of the standard COMSOL PDE equations. You might need to define intermediate variables and new BC for these
Hi you need to reexpress your model to fit into the parameters of the standard COMSOL PDE equations. You might need to define intermediate variables and new BC for these -- Good luck Ivar
Posted: 1 decade ago 29.01.2013, 00:26 GMT-5
thanks for response. Please let me know what do you mean by new bc for these equations.
khalid
[QUOTE] Hi you need to reexpress your model to fit into the parameters of the standard COMSOL PDE equations. You might need to define intermediate variables and new BC for these -- Good luck Ivar [/QUOTE] Hi thanks for response. Please let me know what do you mean by new bc for these equations. khalid
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 29.01.2013, 02:45 GMT-5
I don't think you need to define any intermediate variables. That is typically only necessary if you have derivatives of order higher than 2 in your equations. I would formulate this as two coupled 1D PDEs along a line from 0 to 1 with two dependent variables: n and T (using a single Coefficient Form PDE in COMSOL). The equations look quite nonlinear but should be possible to solve.
Magnus Ringh, COMSOL
Hi, I don't think you need to define any intermediate variables. That is typically only necessary if you have derivatives of order higher than 2 in your equations. I would formulate this as two coupled 1D PDEs along a line from 0 to 1 with two dependent variables: n and T (using a single Coefficient Form PDE in COMSOL). The equations look quite nonlinear but should be possible to solve. Best regards, Magnus Ringh, COMSOL
