Robert Koslover
Certified Consultant
20.11.2013, 13:31 GMT-5
Believe it or not, this is a feature, not a bug! When you specify the power going into the port, you are NOT actually forcing the boundary condition there into a state where it will actually have that net-overall power going into the port. Rather, you are only setting the forward-going power at that port. In general, there will also be a reverse-going power there, due to reflections or impedance mismatches somewhere in your system. This fact allows the proper computation of parameters such as S_11 (where the port is port #1), for example. When you do your integral of the power density over the port, both forward-directed and reverse-directed power flow is included, which is why you got less than 1W. (Note also that to get accurate numbers, you should generally mesh your ports relatively finely.)
21.11.2013, 01:43 GMT-5
Sir,
Thank For your reply..
I think I understand your explanation and In this case how will one able to find only the forward-going power at that port after running the program.
Regards
Binoy Chacko
Sir,
Regards
Binoy Chacko
Robert Koslover
22.11.2013, 20:21 GMT-5
The "forward-going" power is 1W, since that is what you specified. P_total_input = P_forward - P_reverse. You can also do integrals over various surfaces (and/or volumes, if heating/loss is involved) to confirm energy conservation, and/or just to get a feel for the magnitude of numerical errors in the model. And you can plot quantities like S11, that relate to the power reflected. Look up "s-parameters" in the help system.
24.11.2013, 21:20 GMT-5
Sir,
Regards
Binoy Chacko
Dear Binoy,
A "PML" layer at the end of structure will help you to avoid any reverse wave!
Good luck! :)
[QUOTE]
Sir,
Regards
Binoy Chacko
[/QUOTE]
Dear Binoy,
Good luck! :)
29.11.2013, 01:32 GMT-5
hi,
Thank you for your reply.
We are trying to do as you said..
Regards
Binoy Chacko
hi,
Regards
Binoy Chacko
