Importing real data heat flux boundary condition to COMSOL
Hello all,
I'm working on a 2D transient heat transfer project and I can't figure out how to import real data for heat flux vs.time in COMSOL. It only allow me to input a fix value or function, not discrete data points.
Any idea?
Thank you very much,
Vinh
6 Replies Last Post 19.05.2013, 10:04 GMT-4
Posted: 1 decade ago 21.02.2013, 01:54 GMT-5
check the help/doc on the Definition Function Interpolation (+read from File)
Hi check the help/doc on the Definition Function Interpolation (+read from File) -- Good luck Ivar
Posted: 1 decade ago 21.02.2013, 22:07 GMT-5
Hi Ivar,
I was able to create a function with "interpolation function". Now do you know how could I use that function as my inward heat flux in my model?
Vinh
Hi Ivar, I was able to create a function with "interpolation function". Now do you know how could I use that function as my inward heat flux in my model? Thank you very much, Vinh
Posted: 1 decade ago 22.02.2013, 01:43 GMT-5
if you have an interpolation function of the type int1(arg1,arg2), you simply use it in the place for your results calling it as int1(T,H). Now in COMSOL convention, T is a field (T,x,y,z,t) and H too, hence the use of this function implies that you have selected a domain, or boundary where x,y,z are defined (and t by the solver or t=0 the default for non time domain).
Again if you are in 2D COMSOL defaults set z=0, just as in 1D y=z=0 by default, but they are still there ;)
Hi if you have an interpolation function of the type int1(arg1,arg2), you simply use it in the place for your results calling it as int1(T,H). Now in COMSOL convention, T is a field (T,x,y,z,t) and H too, hence the use of this function implies that you have selected a domain, or boundary where x,y,z are defined (and t by the solver or t=0 the default for non time domain). Again if you are in 2D COMSOL defaults set z=0, just as in 1D y=z=0 by default, but they are still there ;) -- Good luck Ivar
Posted: 1 decade ago 22.02.2013, 15:16 GMT-5
Hi Ivar,
My interpolation function is as following:
t f(t)
0 0.613
60 0.613
120 0.637
180 0.651
240 0.613
300 0.508
360 0.208
420 0.089
480 0.201
540 0.508
600 0.681
"Units"
Arguments: s
functions: W/m^2
Now in my heat flux boundary condition: q0 = int1(t) W/m^2
Is it the right way to call out interpolation for boundary condition? my boundary condition is heat flux vs. time
Thank you,
Vinh
Hi Ivar, My interpolation function is as following: name: int1 t f(t) 0 0.613 60 0.613 120 0.637 180 0.651 240 0.613 300 0.508 360 0.208 420 0.089 480 0.201 540 0.508 600 0.681 "Units" Arguments: s functions: W/m^2 Now in my heat flux boundary condition: q0 = int1(t) W/m^2 Is it the right way to call out interpolation for boundary condition? my boundary condition is heat flux vs. time Thank you, Vinh
Posted: 1 decade ago 23.02.2013, 08:49 GMT-5
that look correct for me, but you should always recheck your results ;)
note that:
1) in the function definition "t" is a dummy variable, you can call a function with any expression or variable name
2) if you define the units in the function definition then you do not need (and should not double up) units in the expression
Hi that look correct for me, but you should always recheck your results ;) note that: 1) in the function definition "t" is a dummy variable, you can call a function with any expression or variable name 2) if you define the units in the function definition then you do not need (and should not double up) units in the expression -- Good luck Ivar
Posted: 1 decade ago 19.05.2013, 10:04 GMT-4
Hi Ivar,
i've managed to import experimental datas on interpolation function. However, when i want to call this function in boundary condition, it says "unknown variable"..i was looking to apply force in function of time..can you help me?
Wan
Hi Ivar, i've managed to import experimental datas on interpolation function. However, when i want to call this function in boundary condition, it says "unknown variable"..i was looking to apply force in function of time..can you help me? Best, Wan
