Why auxiliary sweep show the same results when sweeping 2 parameters?
When I use an auxiliary sweep in topology optimization to sweep volume constraint and projection slope, my sweep goes like:
  • fv: 0.8, 0.7, 0.6
  • beta: range(1, 5, 41)
I thought the sweep should proceed like this:
  1. fv = 0.8, beta = 1: Run topology optimization until the objective reaches the maximum. This might take about 5 steps to obtain an optimized structure.
  2. Update beta: fv = 0.8, beta = 6
fv = 0.8, beta = 11
fv = 0.8, beta = 16
fv = 0.8, beta = 41
  1. Update fv to 0.7:
fv = 0.7, beta = 1
fv = 0.7, beta = 6
fv = 0.7, beta = 11
fv = 0.7, beta = 16
fv = 0.7, beta = 41
  1. Update fv to 0.6:
fv = 0.6, beta = 1
fv = 0.6, beta = 6
fv = 0.6, beta = 11
fv = 0.6, beta = 16
fv = 0.6, beta = 41
The simulation should finish after this sequence. However, when I check the obtained data, why are the data values for fv = 0.8, 0.7, and 0.6 all the same?
1 Reply Last Post 25.06.2024, 07:05 GMT-4
Kristian Ejlebjærg Jensen COMSOL Employee
Posted: 2 months ago 25.06.2024, 07:05 GMT-4
Hi Bruce
It sounds like you want to use continuation, but the auxilliary sweep is for inner sweeps/load cases, while you need an outer sweep to do continuation. You might want to have a look at bracket_topology_optimization_stl in the Application Library.
Kristian E. Jensen,
Technical Product Manager, Optimizationn
Hi Bruce It sounds like you want to use continuation, but the auxilliary sweep is for inner sweeps/load cases, while you need an outer sweep to do continuation. You might want to have a look at bracket_topology_optimization_stl in the Application Library. Best regards, Kristian E. Jensen, Technical Product Manager, Optimizationn
Reply
