PCF, PML
I am designing a PCF with hexagonal pattern having five air hole rings.
pitch = 1 um.
air filling fraction = 0.90
i have used circular PML to get the imaginary part of refractive index.
what should be thickness of PML ?
5 Replies Last Post 15.02.2013, 03:10 GMT-5
Hello Selim Habib
Posted: 1 decade ago 04.02.2013, 12:45 GMT-5
A good rule of thumb is to make the PML thickness equal to a few times the wavelength you are using.
cheers,
Felipe
A good rule of thumb is to make the PML thickness equal to a few times the wavelength you are using. cheers, -- Felipe
Posted: 1 decade ago 04.02.2013, 13:02 GMT-5
Actual thickness of PML domain is not important. Important is to place 4-5 elements through the thickness of PML domain. For better performance, used sweep mesh in 3D PML domain, or mapped mesh in 2D PML domain.
Sergei
Actual thickness of PML domain is not important. Important is to place 4-5 elements through the thickness of PML domain. For better performance, used sweep mesh in 3D PML domain, or mapped mesh in 2D PML domain. Regards, Sergei
Posted: 1 decade ago 04.02.2013, 13:29 GMT-5
Wow!
learning a new thing everyday, thanks!
Felipe
Wow! learning a new thing everyday, thanks! -- Felipe
Posted: 1 decade ago 04.02.2013, 13:35 GMT-5
Additional note regarding PML.
It is true, however, that boundary of PML domain should not be placed too close to the structure. Distance between structure and interior boundary of PML domain should be, at least, comparable to wavelength.
Sergei
Additional note regarding PML. It is true, however, that boundary of PML domain should not be placed too close to the structure. Distance between structure and interior boundary of PML domain should be, at least, comparable to wavelength. Regards, Sergei
Posted: 1 decade ago 15.02.2013, 03:10 GMT-5
Thanks every one.
Faced another problem. Now i am designing on hexagonal structure PCF of six air-hole rings and successfully
interface comsol 4.2 with matlab live link. The problem is that it takes a lots of time to simulate in Matlab when simulation is done in matlab.
Is there any procedure to reduce the time.
Thanks in advance.
Thanks every one. Faced another problem. Now i am designing on hexagonal structure PCF of six air-hole rings and successfully interface comsol 4.2 with matlab live link. The problem is that it takes a lots of time to simulate in Matlab when simulation is done in matlab. Is there any procedure to reduce the time. Thanks in advance.
