Frequency Domain Study
I'm starting to use Comsol and I'm trying to do a frequency domain study on a poroelastic material subject to a sinusoidal load which frequency is in the range 1 to 100 Hz. My problem is that I don't know how to define this periodic load, can someone please help me?
Greta
4 Replies Last Post 20.10.2012, 14:46 GMT-4
Posted: 1 decade ago 16.10.2012, 07:39 GMT-4
I was struggling with as well with acoustics, but I concluded that if you do a frequency domain study COMSOL assumes that loads on your system are in a sinusoidal frequency.
Posted: 1 decade ago 16.10.2012, 10:32 GMT-4
the external loads / forces you apply are ALL considered as amplitudes (might be complex) of the frequency span, and the frequency is defined in the solver node, as a value or a range
This is the default way for harmonic developments, check the equation tab of the main physics nodes
Hi the external loads / forces you apply are ALL considered as amplitudes (might be complex) of the frequency span, and the frequency is defined in the solver node, as a value or a range This is the default way for harmonic developments, check the equation tab of the main physics nodes -- Good luck Ivar
Posted: 1 decade ago 20.10.2012, 08:44 GMT-4
Hi Ivar,
thanks for your help. I checked the equations of the frequency domain and, from what I understand, the frequency study considers as periodic only Fv ( a body load) while I'd like to simulate a periodic boundary load. In fact, I'm trying to simulate the effect of an indentation test on the poroelastic material. Can you please tell me how to reach this goal?
Greta
Hi Ivar, thanks for your help. I checked the equations of the frequency domain and, from what I understand, the frequency study considers as periodic only Fv ( a body load) while I'd like to simulate a periodic boundary load. In fact, I'm trying to simulate the effect of an indentation test on the poroelastic material. Can you please tell me how to reach this goal? Thanks, Greta
Posted: 1 decade ago 20.10.2012, 14:46 GMT-4
Normally all loads are "harmonic", not only body loads, also boundary loads. Check carefully, and i.e. make a simple example to get convinced
Hi Normally all loads are "harmonic", not only body loads, also boundary loads. Check carefully, and i.e. make a simple example to get convinced -- Good luck Ivar
