Henrik Sönnerlind
COMSOL Employee
1 year ago
09.02.2023, 05:36 GMT-5
The line type and how smoothing is applied (in the Quality section) are independent selections.
If you get jumps between elements in a line graph, then you may have to use another smoothing option.
If you are 'missing' parts of the line, then the probable cause is that your expression is not possible to evaluate everywhere along the line. You could try to graph isnan(expression). If that evaluates to a nonzero value anywhere, there is a problem in your expression.
Henrik Sönnerlind
COMSOL
If you are 'missing' parts of the line, then the probable cause is that your expression is not possible to evaluate everywhere along the line. You could try to graph *isnan(expression)*. If that evaluates to a nonzero value anywhere, there is a problem in your expression.
1 year ago
09.02.2023, 23:16 GMT-5
Hi Henrik, thank you so much! It worked now.
