Damped Eigenfrequency Analysis
Posted 22.06.2012, 07:02 GMT-4 MEMS & Nanotechnology, MEMS & Piezoelectric Devices, Structural Mechanics Version 4.2a 13 Replies
have you added some damping right click the linear elastic material node and add damping, then select the right type, you can start with isotropic loss factor (eta = 1/2/Q) but its worth to study the others more in detail too, check the doc
Thanks for the reply. I haven't added any damping. I am particularly looking to evaluate Q value for a particular mode. My model is based on the attached example, where damped eigenfequency analysis was used.
Should I use analytical or experimental Q value For isotropic loss factor?
if you do not add any material damping, and have no other damping mechanism then I do not see how you can do a damped eigenfrequency analysis ;)
If you have a measurement of eta or Q_factor and then derive an eta, you could use that to start with, but often the Rayleigh (alpha, beta) are more suited, but it requires more material property data measurements as these are frequency dependent.
And damping is very dependent on the means of assembly: bolt, screw, welding, and contact surface finish + pressure loads, w.r.t micro-slipping, and how these parameters vary with time after many temperature cycles or whatever your parts might survive
A very interesting and challenging domain, unfortunately too little documented and it's difficult to use a model validation for another different case
I have added a loss factor based on Q calculated using an analytical solution. The eigenfrequency analysis gives a Q value closer to the on I had used for loss factor. As I am interested in thermoelastic damping, I am not getting a reasonable temperature profile of my model. I don't understand why the mechanics and heat transfer modes are not coupling. Do you have any advice for me?
Indeed if you enter a Q value as the eta function for isotropic damping you will get a response very close to the theory, what might make some differences, is that in COMSOL you take into account the full 3D shape of your model, and in many "theory" approaches one uses "ideal modes", this can make some differences.
I believe there is a thermoelastic damping axample somewhere in the model library, there was at least, or was that from one of the courses ?
You need to couple the stress or deformation to the heat dissipating mode, and then couple back the temperatre field to the stress etc, I do not believe this is done "as is " in calssical "solid" physics, you need to look after some of the coupled physics.
Now I also see in V4.3 there are many new energy variables, to probably help us validate the physics coupling. But I still need my full holiday time to read the 60MB of pdf we received with the new release :)
As the change in tempearature in thermoelastic damping of a material is due to rapid change in stresses, the heatsource equation for Isotropic materials consists of derivatives of strains in spatial direction. I am unable to implement the heat source equation in the model. For which the temperature profile is not obtained.
unfortunately I do not have any examples to propose, but it is a subject I'll have to catch, hopefully its better implemented in v4.3 in the new non-linear material mode, as I have an important modelling to do with wheat exchange in NiTi material under vibration loads, and the realted thermal effects.
So for the moment I'm in the reading phase, and desparately looking for good COMSOL examples even "just" on classical shape memory models
Thanks for the reply. I contacted the support and they have sent me the TED model in 4.2a. Pretty happy with that.
As I am new to COMSOL, I am having some problem implementing some equation. Could you please help how would I implement the follwoing equation (this is a part of my heat source equation)? Is it possible to write in this form?
δ/δt(εxx+εyy+εzz)
you need to get the full COMSOL names with the related prefixed (depends on the physics used. I have noticed that in the new 4.3 doc there are detailed description of all (most ?) internal variables you can find in the Results pull down list
I have tried to do the exactly the same modelling that was sent to me by COMSOL. But still I can't get the results. I have double checked everything between my model and COMSOL model. Still no result. I am pasting the log of the rtwo simulations. According to my log something is not right. But don't know how to correct it. Can you please help what is wrong... :(
Why the number of degrees of freedom is different from mine?
COMSOL MODEL:
Eigenvalue Solver 1 in Solver 1 started at 25-Jun-2012 16:37:14.
Eigenvalue solver
Number of degrees of freedom solved for: 2808.
Nonsymmetric matrix found.
Scales for dependent variables:
mod1.u: 0.00094
mod1.T: 21
mod1.wZ: 2.9e+002
Iter ErrEst Nconv
1 0.018 1
2 0.019 1
3 0.024 1
4 0.015 1
5 0.033 1
6 0.015 1
7 0.012 1
8 0.012 1
9 0.0022 1
10 0.0012 1
11 0.018 1
12 0.0072 1
13 0.031 1
14 0.00019 1
15 0.00027 1
16 0.017 1
17 0.00024 1
18 0.00017 1
19 0.0098 1
20 0.0063 1
21 0.0032 1
22 0.0025 1
23 0.0014 1
24 1.7e-005 1
25 7e-006 1
26 9.5e-006 1
27 1.5e-006 1
28 0.00032 1
29 3e-005 1
30 0.015 1
31 6.9e-008 2
530 linear system solutions.
530 matrix multiplications.
529 re-orthogonalizations.
Eigenvalue Solver 1 in Solver 1: Solution time: 3 s.
MY MODEL:
Eigenvalue Solver 1 in Solver 1 started at 25-Jun-2012 16:31:35.
Eigenvalue solver
Number of degrees of freedom solved for: 2247.
Symmetric matrices found.
mod1.u: 3.5e-006
mod1.wZ: 1
Iter ErrEst Nconv
1 0 1
20 linear system solutions.
20 matrix multiplications.
19 re-orthogonalizations.
Eigenvalue Solver 1 in Solver 1: Solution time: 0 s.
the "Comsol" model seem to have 3 dependent variables yours only 2, the T is missing, this could explain it , but there might be many other things too
Thanks. FIxed the problem. Could you please explain why rescaling of PDEs is necessary for equation based modelling?
rescaling is motly required all the time, its linked with the limited resolution of the binary numers, you get easily numerical overflows or underflows if you do not make all your values behave close to "1" via a constant scale, that you undo once you have inverted all your matrices. Its standard numerical techniques, but often far from trivial. It means more or less oyu should have a good knowledge of your results before you solve, which is not always the case if you have not done your homeworks of first estimatinmg the values by hand. Hence you might ned to run your case a few times to better converge with the scaling, at each new run
Suggested Content
- FORUM Increasing Precision of Eigenfrequency Analysis
- BLOG How to Model Different Types of Damping in COMSOL Multiphysics®
- BLOG Intro Model: Studying the Signal Strength of RF Coils
- BLOG Biomechanical Model Evaluates Human Response to Vibrations
- KNOWLEDGE BASE Error: Failed to Find a Solution. Returned Solution is Not Converged
