15.06.2012, 14:06 GMT-4
if you are only changing a BC (boundary condition) and not touching your geometry, and you are in a stationary study: then define parameter, call it "Param" or something nice, then replace your BC voltage value V0 by V0*Param. Go to the stationary study, select the "continuation" sweep tab (one of the last of the solver view) and turn it on and define th Param as parameter to sweep then add a range for the values you want like "range(0.5,0.1,2) or whatever is relevant.
Then solve, you will get a series of results out, that you can then posprocess with "Derived Variables" or multiple plots at will
