Permanent magnet falling in a tube
Hi everybody,
In one of my tests I wanted to see if COMSOL takes care and computes the eddy currents, or if I should make it compute them. (if you have an immidiate answer, I'll be glad, by the way :) ) So I wanted to create the simplest test model I could find - and the first one I thought of was a magnet falling in a tube by gravity. In case I'm not clear - www.youtube.com/watch?v=kU6NSh7hr7Q around 1:45 is the model I'm talking about.
Anyway - I constructed the model in an axisymmetric 2D. Geometry is easy and fine, but I'm having trouble with the rest. I inserted both Structural mechanics and Magnetism - one to make it fall, and the other to study our goal. The model solved, but from the results I am seeing I'm not comfortable enough with it. I'm not sure it is correct, and in no way can I actually see the displacement of the magnet through time. It always seems to show me the displacement *field*, which I'm not sure what it is(I'm not a native English speaker).
Can you review the model and see?
Thank you for your time,
Shoval.
3 Replies Last Post 11.03.2012, 07:00 GMT-4
Posted: 1 decade ago 06.03.2012, 07:09 GMT-5
I can tell you that COMSOL does calculate eddy currents in the AC and RF application modules.
Cheers
Edgar
Hi I can tell you that COMSOL does calculate eddy currents in the AC and RF application modules. Cheers Edgar
Posted: 1 decade ago 09.03.2012, 02:02 GMT-5
If you read French (well math is universal ;) you can try this exercice found on google:
iai.heig-vd.ch/fr-ch/Enseignement/Supports/Physique%20%C3%A9lectricit%C3%A9%20et%20magn%C3%A9tisme%20(PHY2)/Aimant_dans_un_tube.pdf
It's part of the training course of a former colleague, now professor at the heigvd
We had some older COMSOL files too somewhere, but I have not amanged to find them back, it's solved rather simply with the latest version in 2D-axi
Hi If you read French (well math is universal ;) you can try this exercice found on google: http://iai.heig-vd.ch/fr-ch/Enseignement/Supports/Physique%20%C3%A9lectricit%C3%A9%20et%20magn%C3%A9tisme%20(PHY2)/Aimant_dans_un_tube.pdf It's part of the training course of a former colleague, now professor at the heigvd We had some older COMSOL files too somewhere, but I have not amanged to find them back, it's solved rather simply with the latest version in 2D-axi -- Good luck Ivar
Posted: 1 decade ago 11.03.2012, 07:00 GMT-4
Hi again,
I opened the file but I could not quite understand what it was describing just by reading the equations :( nevermind though; for some reason I cannot attach my attempt at making the model. Is there any chance you can find the model you talked about, or even create a new one(my test model took less than 10 minutes to be fully created from scratch) and attach it here or link me to it?
Thanks for your time Ivar! :)
Shoval~
Hi again, I opened the file but I could not quite understand what it was describing just by reading the equations :( nevermind though; for some reason I cannot attach my attempt at making the model. Is there any chance you can find the model you talked about, or even create a new one(my test model took less than 10 minutes to be fully created from scratch) and attach it here or link me to it? Thanks for your time Ivar! :) Shoval~
