27.02.2012, 01:32 GMT-5
what if you replace terminal 2 by a GND node on the same boundary ?
Furthermore you should add an epsilonr = 1 to your materials, even if its not needed for the solver, its needed for many of the postprocessing variables, but so long you do not use them it might be OK
27.02.2012, 01:55 GMT-5
Thanks for quickly reply.
I'v replaced terminal 2 by GND node and it works well
but, when i checked current output using Derived Values,
Output current is about 360mA.
I don't know whether measuring current is incorrect or simulation condition is incorrect.
27.02.2012, 02:23 GMT-5
both are "correct", but it seems that you have not read carefully the KB about flux calculations.
if you use a Derived Values Globa Evaluation - variable electric current - port and terminal + ec.I0_1
you will then get a more accurate value obtained with the weak formulation (already integrated over the port area)
if you change the mesh density on your pads you will notice the current change, by the way use rather
ec.normJ = sqrt(realdot(ec.Jx,ec.Jx)+realdot(ec.Jy,ec.Jy)+realdot(ec.Jz,ec.Jz)) Current density norm
than your product, ... or ?
27.02.2012, 04:42 GMT-5
Stupid question, what's KB?
first of all, thanks
27.02.2012, 04:59 GMT-5
sorry, it the Knowledge BASE see
www.comsol.com/support/knowledgebase/browse/900/
There are no stupid questions, at most stupid answers ;)
http://www.comsol.com/support/knowledgebase/browse/900/
07.03.2012, 05:43 GMT-5
Thank you for your adviser.
By reading KB, I know that when I set terminal condition to the electrode, it is hard to get exact flux value on that surface which I give the terminal condition
Then, If I calculate flux in the other surface, can I sure that value?
For example, I made cylinder electrode in the rectangle model and I set 1mA on the upper side.
After calculation, I measure the current on the lower side of the electrode by surface integration
Then, is the output current proper?
