inversion
Someone told me that it might be possible to use Comsol to solve geophysical problems using the optimization module.
I have yet to have the optimization module but I downloaded the Livelink for matlab manual and read the section on Using solver Configurations.
My question is, is it possible for Comsol to do a serious inversion calculation, solving the objectif function? I have seeing the "Aquifer Characterization" model but its not what I'm looking for.
For example, if I wish to do a 3D resistivity inversion, can Comsol do both the modeling (yes) and inversion? Or I have to split the modeling with Comsol and inversion with Matlab?
If so how? I would like to know before making any decision on purchasing the modules or not.
Any documentations, examples, comments, etc... are welcome!
Thank you in advance!
1 Reply Last Post 08.02.2012, 11:05 GMT-5
Posted: 1 decade ago 08.02.2012, 11:05 GMT-5
the method of resolution in COMSOL corresponds to a least square fitting to unknown data if you set it up for that, check the optimisation chapter, if you have a single variable to resolve you can run it like that, if you have a complex optimisation to set up, the pre-cooked math in the optimisation module is ready made such to simplify your job.
This can be done "all in one, or via 2 coupled solver runs all depends how you set up your model
Hi the method of resolution in COMSOL corresponds to a least square fitting to unknown data if you set it up for that, check the optimisation chapter, if you have a single variable to resolve you can run it like that, if you have a complex optimisation to set up, the pre-cooked math in the optimisation module is ready made such to simplify your job. This can be done "all in one, or via 2 coupled solver runs all depends how you set up your model -- Good luck Ivar
