How to create a crack in a plate
I want to create a crack in a 2D Aluminum plate, and I was wondering, If I need to give any boundary condition to it, like a weak constraint or anything of that sort?
3 Replies Last Post 04.06.2012, 11:58 GMT-4
Posted: 1 decade ago 12.12.2011, 16:10 GMT-5
I would propose to use assembly mode and then apply a continuity by hand, but the best is to look at the mdel of a crack in the model library (at least there were one in 3.5)
Hi I would propose to use assembly mode and then apply a continuity by hand, but the best is to look at the mdel of a crack in the model library (at least there were one in 3.5) -- Good luck Ivar
Posted: 1 decade ago 03.06.2012, 15:20 GMT-4
Have you found a solution to creating a crack in a plate?
Posted: 1 decade ago 04.06.2012, 11:58 GMT-4
One way is to partition the plate into two separate geometries along the direction of the crack, use Assembly instead of Union as a final geometry operation and add a Boundary Similarity model coupling between the two parts of the plate that are not cracked. The Boundary Similarity will couple the displacements of the two sides. There is, as Ivar pointed out, a basic 2D crack example in the documentation. In that example the crack is along a line of symmetry so the geometry was easier to define.
Nagi Elabbasi
Veryst Engineering
One way is to partition the plate into two separate geometries along the direction of the crack, use Assembly instead of Union as a final geometry operation and add a Boundary Similarity model coupling between the two parts of the plate that are not cracked. The Boundary Similarity will couple the displacements of the two sides. There is, as Ivar pointed out, a basic 2D crack example in the documentation. In that example the crack is along a line of symmetry so the geometry was easier to define. Nagi Elabbasi Veryst Engineering
