Henrik Sönnerlind
COMSOL Employee
6 years ago
30.04.2019, 09:22 GMT-4
The quoted expression is the definition of a parameter in the Wave Propagation in Rock Under Blast Loads example. That example is based on data in a report I wrote some 15 years ago, so I do not remember all details.
The force amplitude 140e6[N] must be considered just as a value that may be known from for example experience. In real life, there is of course some area on which the explosive acts, so the force is derived from a pressure amplitude times that area (which is not directly known in this example )
The fact that the peak pressure during an explosion is proportional to the power "2/3" of the amount of explosive is however well established in that field, if I remember correctly.
Henrik
Henrik Sönnerlind
COMSOL
The quoted expression is the definition of a parameter in the *Wave Propagation in Rock Under Blast Loads* example. That example is based on data in a report I wrote some 15 years ago, so I do not remember all details.
The force amplitude 140e6\[N\] must be considered just as a value that may be known from for example experience. In real life, there is of course some area on which the explosive acts, so the force is derived from a pressure amplitude times that area (which is not directly known in this example )
Henrik
6 years ago
02.05.2019, 08:09 GMT-4
I think I understand, thank you very much for your answer.
Mr. Li
Mr. Li
