How to efficiently output the resulting plots from a parametric sweep?
Posted 19.09.2018, 02:21 GMT-4 General, Parameters, Variables, & Functions, Results & Visualization Version 5.3a 0 Replies
Comsol v5.3a
I have a parametric sweep solution from two varied parameters (viscosity and inflow) for a stationary fluid simulation. When I generate my reports, it only generates the plots for the currently selected set of parameters on the referenced plot. How can I output all of my plots without having to manually change the parameters on each plot one by one? Making a separate report for each doesn't seem feasible since they would all reference the same plot... The only other workaround I can see is copying the plots each plot to the clipboard and into an external document, but this is extremely time-consuming as well. Is there something I'm missing?
Hello Ross Booth
