19.03.2011, 18:24 GMT-4
Have you created a solid windtunnel? Is it the wing-like object in the middle that you want to model in a freestream?
In that case make a solid cube around the object, set the cube to air, the object to your chosen material and select two sides of the cube as inlet and outlet.
21.03.2011, 15:56 GMT-4
YES, I want to model a wing-like object in the middle. I use the weakly compressible Navier- Stokes Module, and I made a solid cube around it and the inlet pressure is 0.2MPa and the outlet pressure is 0.1MPa, but when compute, there are some errors.
Exception:
com.femlab.jni.FlNativeException: Failed to evaluate expression
- Expression: d(((Lentr_chns*((-2*eta_chns*uTx+p)*test(uTx)-eta_chns*(uTy+vTx)*test(uTy)-eta_chns*(uTz+wTx)*test(uTz))-Pinl_chns*nx_chns*test(u)-h^2*(Lentr_chns*(pTx-eta_chns*(uTxx+uTyy+uTzz))+Pinl_chns*nx)*test(pTx)/(24*eta_chns))-(0))*(dvol),{test@1})
Failed to evaluate variable
- Variable: eta_chns
- Geometry: 1
- Boundary: 1
Stack trace:
at evaltree.cpp, row 866, ()
at xevalutil.cpp, row 2612, ()
at com.femlab.solver.FlSolver.femStatic(Native Method)
at com.femlab.solver.FemStatic.run(Unknown Source)
at com.femlab.server.FlRunner.run(Unknown Source)
at com.femlab.util.i.run(Unknown Source)
at com.femlab.util.aa.run(Unknown Source)
Please help remove thse errors.
Best regards!
Kehui Chen
Exception:
- Geometry: 1
- Boundary: 1
Stack trace:
Best regards!
Kehui Chen
22.03.2011, 02:37 GMT-4
I suspect you are missing a material property
Zoran Vidakovic, COMSOL
COMSOL Employee
22.03.2011, 11:11 GMT-4
Hi Kehui
What you have imported are the solid bodies. So, you need actually the inverse geometry. Derive a domain for the fluid and apply the fluid flow physics there.
Checked model with v4.1...
Zoran
Hi Kehui
Zoran
