Jeff Hiller
COMSOL Employee
8 years ago
31.01.2017, 16:02 GMT-5
Hello Hamed,
To avoid having to re-solve the model, after you add the line you need to use "Update solution" instead of "Compute". Then compute the line average the usual way.
Hello Hamed,
8 years ago
14.02.2017, 18:00 GMT-5
Thank you Jeff for the answer.
My question was how to define a line in the domain so I can select it in the line average?
Hamed
Hamed
Gunnar Andersson
COMSOL Employee
8 years ago
15.02.2017, 02:49 GMT-5
I suggest that you create a Cut Line data set.
[QUOTE]
[/QUOTE]
Jeff Hiller
COMSOL Employee
8 years ago
15.02.2017, 08:51 GMT-5
Indeed, Gunnar's solution is better than mine.
If for some reason you still decide to do it the way I mentioned above, just draw the line like you draw any line in COMSOL: in the Geometry branch of the Model Builder tree use a Polygon of the Open Curve type.
8 years ago
22.02.2017, 21:33 GMT-5
Thank you Gunnar and Jeff.
