2d line integration (Circle to Sphere)
Hi everyone,
I'm trying to solve a creeping flow problem in 2d, using circles. I have a sphere moving in fluid and I want to integrate the shear stress in the x direction, to obtain the drag on a sphere of this size radius. I am not getting the correct answer by integrating it one time as a line integral, so I was thinking I will need to somehow integrate again to obtain the shear stress on the entire surface of a sphere.
How can I do this, using the 2d module? The 3d module is giving me too much trouble meshing, so 2d will simplify things substantially.
Thank you,
Adam
2 Replies Last Post 03.06.2016, 13:58 GMT-4
Posted: 9 years ago 15.04.2016, 15:51 GMT-4
Hello Adam,
Your model should be 2D axisymmetric (not 2D, otherwise you're modeling a cylinder, not a sphere), and the geometry should involve a rectangle minus a half disc. Assuming you've set it up that way, you can compute the line integral on the perimeter of the half-disc of the z stress, making sure to check the "compute surface integral" checkbox so the "2*pi*r" factor is factored in the integration.
Hello Adam, Your model should be 2D axisymmetric (not 2D, otherwise you're modeling a cylinder, not a sphere), and the geometry should involve a rectangle minus a half disc. Assuming you've set it up that way, you can compute the line integral on the perimeter of the half-disc of the z stress, making sure to check the "compute surface integral" checkbox so the "2*pi*r" factor is factored in the integration. Best regards, Jeff
Posted: 8 years ago 03.06.2016, 13:58 GMT-4
Thank you Jeff, I ended up resulting to this. Appreciate the help!
Adam
Thank you Jeff, I ended up resulting to this. Appreciate the help! Adam
