Frequency domain study - changing the force on a point load with frequency
Posted 06.01.2014, 11:20 GMT-5 Acoustics & Vibrations, Parameters, Variables, & Functions, Studies & Solvers, Structural Mechanics Version 4.3a 1 Reply
I'm having some trouble finding out how to apply a frequency-dependant force.
I have a model where up until now, I've been using a non-varying force of 1N on a point load, then performing the frequency study. To validate a project I am working on, I now need this force to change at each frequency step. The value of this force is in a vector in MATLAB. What I'd like to do is export this vector in some format COMSOL can read, and then 'instruct' COMSOL to vary the force at the point load at each frequency step according to the value of this imported file.
To summarise, I have a frequency study of N steps, and a vector of N length - I want COMSOL to change the point load at X frequency to whatever the value is at X position in the force vector.
How can I achieve this?
I have looked at parametric sweeps but I can't find (or more likely understand) how I can use this to import a csv or txt file from MATLAB. Also, I am under the impression that by using a parametric sweep I would end up with N * N results as COMSOL would run the full frequency study for each value of the parameter I specify. This is entirely undesirable as I can see this taking a long time to process and probably even longer to extract the useful data!
Any help would be greatly appreciated. My Google-Fu has failed me and I have found nothing in the manual that covers this type of study, though I assume a frequency dependent force is not entirely unheard of for people doing acoustic studies?
Many thanks,
Myles
Many thanks,
Myles
1 Reply Last Post 14.01.2014, 09:44 GMT-5
