01.10.2010, 00:56 GMT-4
I actually encountered the same problem.
08.12.2010, 22:04 GMT-5
yes, me also. I've got the same problem. But probably it can be solved via the COMSOL script or/together with MATLAB. Right now, I'm figuring out this way. The script should be able to suppress the built in functions in the GUI, after all the GUI is just a GUI. But very little materials can be found. It's pitty.
Cheers
Pete.
Cheers
Pete.
11.03.2011, 06:35 GMT-5
The 'Particle Tracing with Mass' automatically takes all the forces into account because it computes based on the velocity field that already has these foces "encoded" in it - since velocity field is formed by these forces themselves.
I did manage to visualize e.g. Dean force in a U-shaped channel both by plotting the velocity field on a slice and by tracking a particle through the channel.
The only problem that I could do this only in COMSOL 3.5 but the new 4.0 version seems to be unable to do that.
8 years ago
29.11.2016, 08:15 GMT-5
Hi Daniel,
I've seen your reply about Dean force. Now I'm facing the problem that I cannot visualize Dean force.
It has been a long time since you replied that post, but I need your help very much.
Could you share your way in which you visualize Dean force?
Thank you very much.
Joel
Hi Daniel,
Joel
