Error in parameter domain topological analysis.
Posted 11.11.2015, 20:26 GMT-5 Geometry 0 Replies
I created a parametric surface by interpolation using the z coordinates read from a spreadsheet.
Later i manged to convert it as a part of solid (initially had problems in this but when i made the solid extend across the surface on both the sides such that the surface is not on the edge, it was fine) So after creating the solid I tried to create neighboring solids like normal cylinders. then now when i do normal union/intersection of these solids, i get the "error in parameter domain topological analysis"
I am attaching the comsol file and the text file(for uploading i have renamed it as .mph.txt,when used can be renamed back to .txt) used for creating parametric surface.
Any suggestions on why this problem could be there?
regards
Sivanand
Hello Sivanand Somasundaram
