matlab connect prolbem
hey guys,
I built a model on 3.5a version, and extracted it to a M file on 4.0a version.
Now, after I opened Comsol 4.0a with Matlab, and tried to run the M file, the following error came out:
??? Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: Invalid property value
- Property: descr
X is Y#Description#a string
Stack trace:
at com.comsol.nativeutil.properties.Property.c(Unknown Source)
at com.comsol.nativeutil.properties.aa.set(Unknown Source)
at com.comsol.model.impl.PropValueImpl.set(Unknown Source)
at com.comsol.model.impl.PropFeatureImpl.c(Unknown Source)
at com.comsol.model.impl.PropFeatureImpl$p.a(Unknown Source)
at com.comsol.model.impl.PropFeatureImpl$p.execute(Unknown Source)
at com.comsol.model.clientserver.ClientManagerImpl$d.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Error in ==> model at 759
model.result('pg1').feature('surf1').set('descr', '');
anybody knows what is the majorly wrong with this?
Thank you very much in advance.
2 Replies Last Post 01.02.2011, 07:24 GMT-5
Hello Chen Liu
Posted: 1 decade ago 01.02.2011, 07:16 GMT-5
I get exactlyt he same error with a file that was built in the version 4.1. Is your problem already solved in the meanwhile?
Thanks in advance for your answer.
Hello, I get exactlyt he same error with a file that was built in the version 4.1. Is your problem already solved in the meanwhile? Thanks in advance for your answer.
Posted: 1 decade ago 01.02.2011, 07:24 GMT-5
Hello Chen,
I just found that my error was fixed by replacing the empty space'' by a non-empty string.
So replace
model.result('pg1').feature('surf1').set('descr', '') by
model.result('pg1').feature('surf1').set('descr', 'test');
or something like that.
Hello Chen, I just found that my error was fixed by replacing the empty space'' by a non-empty string. So replace model.result('pg1').feature('surf1').set('descr', '') by model.result('pg1').feature('surf1').set('descr', 'test'); or something like that.
