Where can I change scale of Axis
Hi!
I want a fix scale in a 2D model in the 4.0 version. If I want the x-axis to go from -1.368 to 4.210 exactly, how do I do that? the zooming tool is not god enougth.
Does somebody know, please?
Olivia
3 Replies Last Post 14.09.2010, 15:00 GMT-4
Posted: 1 decade ago 13.09.2010, 08:14 GMT-4
good question, do you have any other ones like that ?
A line graph seems to have few options (in 4.0a but additional subnodes to the graph might come in 4.1, who knows, but only if we eare enough to tell Comsol via "suggest" see www.comsol.eu/contact/ )
On a line graphs (then probably on the other too)
- the box scaling works (but is reset on a new solve)
- You can copy the solution Data set and put a selection filter on the new Solution and plot there from, probably not good enough
But using an X-Axis expression for a line along "y" from 0.01 to 0.1 of the type y*(y>0.05)*(y<0.07) does NOT give desired result, allthough they are logical from a strict programming point of view
Hi good question, do you have any other ones like that ? A line graph seems to have few options (in 4.0a but additional subnodes to the graph might come in 4.1, who knows, but only if we eare enough to tell Comsol via "suggest" see http://www.comsol.eu/contact/ ) On a line graphs (then probably on the other too) - the box scaling works (but is reset on a new solve) - You can copy the solution Data set and put a selection filter on the new Solution and plot there from, probably not good enough But using an X-Axis expression for a line along "y" from 0.01 to 0.1 of the type y*(y>0.05)*(y
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 14.09.2010, 08:53 GMT-4
For a 1D Plot Group you can control the x- and y-axis limits in the plot group's Settings window (under Axis and Grid Settings).
For a 2D Plot Group, you can add one or more View 2D nodes under Results>Views and control the axis settings with the "Lock axis" check box in the View 2D node's Settings window and specify the axis limits and whether to preserve the aspect ratio or not in the Axis subnode's Settings window. You can then control which view to apply to the plots in the 2D Plot Group by selecting any added view from the View list.
I hope this helps.
Magnus Ringh
COMSOL AB
For a 1D Plot Group you can control the x- and y-axis limits in the plot group's Settings window (under Axis and Grid Settings). For a 2D Plot Group, you can add one or more View 2D nodes under Results>Views and control the axis settings with the "Lock axis" check box in the View 2D node's Settings window and specify the axis limits and whether to preserve the aspect ratio or not in the Axis subnode's Settings window. You can then control which view to apply to the plots in the 2D Plot Group by selecting any added view from the View list. I hope this helps. Magnus Ringh COMSOL AB
Posted: 1 decade ago 14.09.2010, 15:00 GMT-4
Hi Magnus
Thanks, I was looking one node level too low, I forgot to open up the higher node sub-items.
As suggestion perhaps you shouild add a clickable "+" on the border: "open all sub-item-levels" ;)
Hi Magnus Thanks, I was looking one node level too low, I forgot to open up the higher node sub-items. As suggestion perhaps you shouild add a clickable "+" on the border: "open all sub-item-levels" ;) -- Good luck Ivar
