Hello Bu Ningbin
21.03.2011, 07:06 GMT-4
Dear abubob...
I saw your question on the comsol forum. I am working exactly with the same kind of modeling but I could not find so far any good example with Comsol. I understood you are working with cone-jet mode. I am trying to model the simple-jet, which is the same with higher flows. Maybe we could discuss a bit and see if we can help eachother to find our way using Comsol. Please let me know if you would like to talk a bit further about this.
Kind regards
Luewton Lemos (luewtonlemos@gmail.com)
Dear abubob...
Kind regards
21.03.2011, 21:01 GMT-4
Dear Luewton Lemos
I'am glad to talk with you. In the past months,I have simulated the cone, but the problem is also existed.The following examples are useful, inkjet nozzle. In simulation, the interface is a thin layer, the physcics parameters should be smooth( density ,visicosity , permitivity) , the div of Maxwell tensor is body force, so the whole regions,can add this force, but only the interface is valid. Another problem is the convergence. The solver should be adjusted, I'm working for this.If you have any questions, we can talk together. Good luck.
bu ningbin
Dear Luewton Lemos
bu ningbin
05.08.2011, 02:29 GMT-4
I am new to this Comsol, as well as finite element simulation, just graduate form degree, now working on electrospray as well. I am still beating around the bush, try to understand the Physics that can be used in electrospray. Mind anyone me give me suggestions? Although Comsol supposed to give friendly GUI but no in electrospray, which deals with electrophoresis with two phase flow, as you mentioned the surface force on droplets and being charged.
17.07.2012, 16:43 GMT-4
Hi Bu
I am working on the same problem.
How did you manage to model the leaky feature of the jet? Did you use electric current (ec) instead of electrostatic? Did your result match what Taylor got in his 1964 paper?
Many thanks
Ahmed
Hi Bu
Many thanks
Ahmed
8 years ago
29.04.2016, 09:26 GMT-4
So I am wondering if you still remember how did simulate this E-jet model? Did you get the model?
