10.09.2010, 05:12 GMT-4
I have no time to llok at your model just now, but do not forget that shell elements have also free rotation DoF's but solid not, so you must link these correctly when you mix solid and shell. You have the new (not yet documened) Rigid connector BC to play with too, or use the antisymmetric strain gradients for teh angles thx, thy, thz
10.09.2010, 05:22 GMT-4
Hi Ivar,
Thanks for your answer. I noticed that you have some post of a model about coupling shell and solid element.
That's a very good example. But my problem seems little different with that one, this model, the all the shell elements are attached to the solid elements, it's like an out layer on some solid.
Do you have some example models or documents on this.
Thanks a lot for your help.
/Xiaogai
Hi Ivar,
/Xiaogai
10.09.2010, 05:44 GMT-4
Well I do not see what is bizarre with your model.
If you take away the graphics refinement and set to "1" and not 4th order, and then use wireframe mesh to see the mesh, you only notice that the shell, being fixed along the external boundary (fixed means absolute fixed, not (only) attached to the bulk model as a rogh shape. Refine your mesh and the roughness will gently decrease, no ?
29.09.2010, 07:23 GMT-4
Hi Ivar!
Thanks a lot for your answer. You were right.
But now I have a new problem regarding shell and solid modeling.
As we can see that in comsol version 4.0a, the shell element is Mindlin Reissner shell element with order from 1st order to 2nd order element.
In the model, I use 3rd order for solid element , 2nd order for shell element. Then I will get a "singularity" problem in the model. But if I tried to change shell element to 1st order, then it works. But it looks strange on the boundary.
My question is, why I got singularity problem if I use 3rd order solid, 2nd order shell,
but it did work if I 3rd order solid, 1st order shell element model?
Is this because of the extra nodes for 2nd order shell doesn't share same with 3rd order solid, while 1st order shell always have same node with 3rd order element?
I attached the model in case I didn't express myself clearly.
Thanks a lot.
Xiaogai
Hi Ivar!
Thanks a lot.
Xiaogai
