How to do remote computing?
Hello guys,
I'd like to do some remote computing but I don't know how to connect two PC's. One- the one I'm working on- needs to log into the Server, right? If I do, it alerts 'Connection refused'. I also haven't set up anything on the Server. There is the Option 'Remote Computing' in the Preferences, but what do I have to insert there?
Could someone tell me about the Basics?
Thanks in advance,
Philipp.
4 Replies Last Post 23.10.2015, 03:09 GMT-4
Posted: 9 years ago 21.10.2015, 10:05 GMT-4
Is your license type the nodelock? If so, you can't connect your computer to server. This means you need to Floating Network License(FNL).
reference to
www.comsol.com/products/licensing
regards,
Is your license type the nodelock? If so, you can't connect your computer to server. This means you need to Floating Network License(FNL). reference to http://www.comsol.com/products/licensing regards,
Posted: 9 years ago 21.10.2015, 10:23 GMT-4
thanks for your reply. I'm just using it in an Enterprise, so I don't definitely know, but we have a certain amount of licenses which we can start COMSOL with at any desktop. So it's my understanding this is an FNL Version.
I guess it's more a network-problem, for certain ports are blocked by default.
Hi, thanks for your reply. I'm just using it in an Enterprise, so I don't definitely know, but we have a certain amount of licenses which we can start COMSOL with at any desktop. So it's my understanding this is an FNL Version. I guess it's more a network-problem, for certain ports are blocked by default.
Posted: 9 years ago 22.10.2015, 01:49 GMT-4
My way when I run COMSOL server on a "number cruncher", and pilot it from my laptop in my office, is to login remotely on the "number cruncher", launch the COMSOL SERVER (the blue Multiphysics server not the "red" Application one) and then I start the COMSOL client ("blue" one again not the "red" Application client) on my laptop and I connect to the server.
You should read through the doc about the Client-Server modus, there are some settings to play with if you want to disconnect and reconnect later without crashing your job
Hi My way when I run COMSOL server on a "number cruncher", and pilot it from my laptop in my office, is to login remotely on the "number cruncher", launch the COMSOL SERVER (the blue Multiphysics server not the "red" Application one) and then I start the COMSOL client ("blue" one again not the "red" Application client) on my laptop and I connect to the server. You should read through the doc about the Client-Server modus, there are some settings to play with if you want to disconnect and reconnect later without crashing your job -- Good luck Ivar
Posted: 9 years ago 23.10.2015, 03:09 GMT-4
Hey Ivar,
I think that's what I was looking for. Thanks alot. :)
Have a nice day,
Philipp.
Hey Ivar, I think that's what I was looking for. Thanks alot. :) Have a nice day, Philipp.
