transient simulation using pipe flow module
Posted 19.10.2015, 08:09 GMT-4 Fluid & Heat, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Geometry, Mesh, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers 1 Reply
Hey
im trying to model 2 concentric pipes, in the inner pipe there is hot water flow(forced convection) and in between the pipes there is closed gap with cold water(natural convection), the outer border is subjected to room temp natural convection.
the inner and outer pipe heat transfer coeff' are modeled by the pipe flow module heat transfer library,
and the closed gap natural convection was modeled as effective thermal conductivity from Holman book correlations.
im trying to estimate the bulk temp of the outlet water flow vs the changes in geometry and flow rate, but it seems that the module does not take into account the thermal mass of the pipe..
do you have any idea how to add it to my model?
i don't want to use 2D axisymmetric model since i have less confident in the results (or am i wrong here?)..
Nadav
Nadav
1 Reply Last Post 22.10.2015, 02:12 GMT-4
