Buckling of a fixed-fixed beam
I am trying to model the buckling of a fixed-fixed beam while one end has a specific displacement.
When I fix a boundary the COMSOL would not let me to define a fixed displacement for that boundary again.
I would appreciate any suggestion regarding this problem.
7 Replies Last Post 03.03.2015, 08:27 GMT-5
Posted: 1 decade ago 07.09.2010, 02:57 GMT-4
if yu fix a boundary, you say u=0 v=0 ... so you cannot then apply a prescribed displacement that is u=disx, v=disy ... if disx and disy are different from "0".
remove the fixed at the end you put only a prescribed displacement and it should solve correctly.
Basically "fixed means" prescribed displacement all = "0"
If you are afraid your prescribed displacement will overstress the items in certain directions, apply a moment, check the ST doc (3.5a) or have a look at the example in the Model Exhange
Hi if yu fix a boundary, you say u=0 v=0 ... so you cannot then apply a prescribed displacement that is u=disx, v=disy ... if disx and disy are different from "0". remove the fixed at the end you put only a prescribed displacement and it should solve correctly. Basically "fixed means" prescribed displacement all = "0" If you are afraid your prescribed displacement will overstress the items in certain directions, apply a moment, check the ST doc (3.5a) or have a look at the example in the Model Exhange -- Good luck Ivar
Posted: 1 decade ago 07.09.2010, 13:31 GMT-4
Dear Ms Momeni
may you explain more! you mean the boundary moves by applying the stress?
Dear Ms Momeni may you explain more! you mean the boundary moves by applying the stress?
Posted: 1 decade ago 07.09.2010, 13:56 GMT-4
Thanks for your response. It solved my problem.
Posted: 1 decade ago 08.09.2010, 01:08 GMT-4
your question is slightly short, but if I got you right, yes, basically stress times strain is the Young modulus. In linear thory the Young modulus is generally considered as a constant so if you apply some stress you will get a displacement (for a fixed-free or free free object), just as if you imply a relative displacement on a fixed free object you will get a resulting stress, no ?
Hi your question is slightly short, but if I got you right, yes, basically stress times strain is the Young modulus. In linear thory the Young modulus is generally considered as a constant so if you apply some stress you will get a displacement (for a fixed-free or free free object), just as if you imply a relative displacement on a fixed free object you will get a resulting stress, no ? -- Good luck Ivar
Posted: 1 decade ago 02.03.2012, 09:02 GMT-5
I was wondering if you actually get the beam to buckle simply by applying the displacement.
Is the applied displacement prescribed in step-by-step mode from 0 ? How about from high displacement?
Doni
Hello, I was wondering if you actually get the beam to buckle simply by applying the displacement. Is the applied displacement prescribed in step-by-step mode from 0 ? How about from high displacement? Doni
Posted: 1 decade ago 02.03.2012, 10:11 GMT-5
for large displacements, turn on the (now since 4.2a in the solver node) geometrical non-linearitites
Hi for large displacements, turn on the (now since 4.2a in the solver node) geometrical non-linearitites -- Good luck Ivar
Posted: 10 years ago 03.03.2015, 08:27 GMT-5
I am trying to include geometric nonlinearities in my model but when I go to the study setting I just get an empty windows.
Why I don't have the possibility of checking "include geometric nonlinearities"?
Hello, I am trying to include geometric nonlinearities in my model but when I go to the study setting I just get an empty windows. Why I don't have the possibility of checking "include geometric nonlinearities"? Thanks
