10 years ago
24.09.2015, 13:38 GMT-4
You have heat coming in but nothing going out. Mayby heat flux from outer walls will handle the problem.
Best regards
Tero Hietanen
Best regards
Tero Hietanen
10 years ago
24.09.2015, 13:58 GMT-4
I defined that around the edge, it will not allow me to define it anywhere else.
It will still not converge. I tried putting a heat flux of 0, and a non-zero value.
Very Respectfully,
Will
Very Respectfully,
Will
10 years ago
24.09.2015, 14:23 GMT-4
I added heat flux with convective heat transfer coefficient. Check model.
Best regards
Tero
Best regards
Tero
10 years ago
24.09.2015, 14:42 GMT-4
Thank you!
So this kind of modelling assumes that the temperature within the heat source is constant? Wouldn't there be a greater internal temperature than what is on the surface?
Very Respectfully,
Will.
Thank you!
Very Respectfully,
Will.
10 years ago
24.09.2015, 15:37 GMT-4
In your current model air is defined as fluid but is not moving (no buoyancy flow). Due to this your block is between solid air which is quite good insulator. If you want to add flow, check this:
www.comsol.com/blogs/using-the-boussinesq-approximation-for-natural-convection/
Best regards
Tero
https://www.comsol.com/blogs/using-the-boussinesq-approximation-for-natural-convection/
Best regards
Tero
10 years ago
24.09.2015, 15:42 GMT-4
That's interesting. Thank you again for the help.
One last question, by any chance do you know if I can simulate the cylinder of copper as a coil of copper wiring and how I would go about doing that?
Very Respectfully,
Will.
Very Respectfully,
Will.
10 years ago
24.09.2015, 16:04 GMT-4
Hmm... maybe defined as solid block but different heat transfer to every axis direction (effective heat conductivity). If wiring is very thin, define coil directly to solid copper.
Best regards
Tero
Best regards
Tero
