Hello Anna Amal
04.02.2011, 09:06 GMT-5
Hello Every one,
I am working on SAW Device Simulation and am new to Comsol. Could any one help me with finding out the frequency response of the SAW Device.
Thank You
Anand
Hello Every one,
Thank You
Anand
05.02.2011, 10:09 GMT-5
I have only 4.1 but when I load in the file, I see:
1) reasonnable geometry that I understand ;)
2) some material constants, but that are not in use as they are not referring to any domain
3) a PZT physics, one for all materials that are redefining all domains as PZT material, which I believe is not the desired case, or ?
4) an eigenfrequency analysis around 218 MHz
You should add a linear exansion node for the Aluminium, and either decide if you use the material data or you define the material data as User specified in the physics node (but not both)
Since you solve also for V, you need to ensure that you have enough BC's for (u,v,w) the structural part (fixed i ok), as well as for V the voltage (you need a GND and a V source). You should also check what impedance you have on the electric circuit as a PZT has different stiffness if the electrodes are open circuit or shorted/grounded
07.02.2011, 09:31 GMT-5
Hello Sir,
Thanks for the suggestions
Hello Sir,
07.03.2011, 07:46 GMT-5
Hello Sir,
I have plotted the current at the electrode where it was 1V and for calculating "I" i have used (pzd.nJ)* 1e-6[m]. I am here with attaching my word file with images for better understating of my model (the way i have set my boundary conditions). please correct me so that i can calculate the resonance frequency. Thanks in Advance.
Anand
Hello Sir,
Anand
08.03.2011, 06:19 GMT-5
Hello Sir,
Anand
Hello Sir,
Anand
08.03.2011, 16:34 GMT-5
I have some problems to follow you, as your initial model was missing a few points such as Elastic material and electric materials definitions for the Aluminium (which is NOT a PZT), then epsilonr of air is not defined (flagged red (!) ) etc
then eps.nJ[A/m^2] is the inward flowing current DENSITY so multiplying it with a boundary length of 1[um] does not give you Amps but Amps per 1[m] depth ([A/m] along Z out of paper)
and you have no voltage supply
09.03.2011, 10:47 GMT-5
Hello Sir,
Thank you! So kindly suggest me the changes to obtain a resonance frequency plot. Please suggest me some papers or any other material or web site where in I could have a better understanding of Comsol in solving my problem as i am beginner.
Thanks in Advance
Anand
Hello Sir,
Thanks in Advance
Anand
09.03.2011, 11:15 GMT-5
when you start with COMSOL, the biggest temptation is to run your complex model at once, this is mostly frustrating, as it is to go through all then examples, but from my experience its the best way:
- view a few videos on the main site
- repeat the exercices in the model library, print out the pdf files and follow the instruction, ask youself way this and that
- if possible, once you get a first catch on COMSOL, take one of the COMSOL courses these are excellent, allows you to get support on the fly and ask questions + hands on exercices, see the main site for dates and locations close to you. Check with your Comsol rep. If you are somewhat remote, at an university or so, find out how to group a series of users and find out with your institution how to go on, to invite COMSOL to your place, it's worth the try, in my opinion, but I'm not COMSOL, so I do not know their conditions and possibilities.
09.03.2011, 12:35 GMT-5
Thanks a lot for your valuable suggestions. Will follow your instructions.
Thanks Again.
Thanks Again.
