calculation of e field in a partially conducting fluid
I am in the process of evaluating Comsol. I have a trial version, but I am struggling to find out if it will simulate what I want..before I spend serious cash on the full version.
Here is my application:
I have essentially a non insulated coaxial structure with a small aperture cut in the outer. The cable is immersed in a partially conducting fluid which penetrates into the cable such that it is contacting the inner (live) conductor and the bare braid. One end of the coax is driven with a low frequency sine wave signal at around 10 kHz at say 10Vpp and the other end is terminated in a 50 Ohm load.
I have an array of metal pads suspended in the liquid, at some distance above the cable and at some distance from the aperture. I would like to find the voltage developed across two of these pads in a 3D space as I move the pads around, adjust the size and shape of the aperture and vary the conductivity of the liquid.
I am assuming I should be using the AC/DC module (not RF) as I am at 10 kHz and the aperture is in the order of a few cm.
Any hints and tips on modelling, is AC/DC the correct tool? I suppose I just want to simulate the electric field in the liquid, which could equally be done at dc rather than 10 kHz. I am convinced this is simply a low freq electric field simulation and that there are no magnetic/TEM fields. I am looking at propagation in a conducting fluid, not in free space. I don't think electrostatic modelling is the correct way forward as I don't have a pure dielectric.
Thanks, Julian.
1 Reply Last Post 17.09.2015, 06:11 GMT-4
Posted: 10 years ago 17.09.2015, 06:11 GMT-4
Julian,
I think you are correct in using AC/DC and also in approximating with a DC setup. I would suggest to use electric currents physics.
The coaxial structure confines magnetic and electric fields essentially into the inner domain of the cable.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Julian, I think you are correct in using AC/DC and also in approximating with a DC setup. I would suggest to use electric currents physics. The coaxial structure confines magnetic and electric fields essentially into the inner domain of the cable. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
