How to apply the AT CUT QUARTZ material
Posted 01.09.2010, 00:10 GMT-4 Materials 6 Replies
This is Yong Hoon Lee From Korea.
I'm a graduate from Kookmin University in Seoul.
I have a quesition "How to apply AT CUT QUARTZ material when the simulation is conducted"
Quartz material exists but I can't see the mateiral which is considered AT CUT anywhere.
Please let me know the method if you know that.
Thank you.
I'm not fmiliar with quartz AT cut material, but for most crystals (such as Si that I do use) COMSOL have a normalised material tensor (if you engage the anisotropic material option) along x,y,z, you must then define your local coordinate(s) to align the tensor with the domain orientation of interest.
I assume therefore that you must define the AT cut direction w.r.t the tensor default coordinates, and then define a local coordinate system that takes the first material AT correction and the domain orientation into account
There is now in V4 a way to show the material orientation in the plot/postprocessing menus once solved, or at least initial conditions loaded (unfortunately not yet when you define the coordinate systems ;)
respecting this first point, you have two way to introduce the AT material :
written the elastic coefficient rotated (see at the annex )
or written the non rotated coefficient and used a coordinate system with a rotation of -35° on the X axis
It works well in eigenfrequency,thermal static analysis and has been validated within my current job
So good luck and don't hesitate to ask me other question....
best regard
PS : all what is described is related to the 3.5 a version and below....
for V4.0a and above it is currently investigated
Yes Thibault is right, there are two ways for the tensor convention in COMSOL !!:
1) PZT applies IEEE convention, for tensor order, it's remined on the screen by the full names written out, check the subscripts
2) classical structural and elsewhere a more natural ordering of the tensor items,
I'm not sure how to check this in the material database though, if you use one convention in the materials, and expect another in the physics, you will get a mess. Hope COMSOL has set a flag for this in their DB, could be worth a question to support, such to be warned before you stand up in front of your clients trying to explain strange results ;).
This is the only place I know that COMSOl does not have an unique definition, and the historical heritage is rather
important and difficult to avoid.
Everywere else COSMOL has unified physics and "traditional" notations, that by itself is a great job.
I am in great need of the material constants of STcut x quartz, like elastic constants, piezoelectric constants and dielectric constants. Do you know how to calculate them? Thanks. MY email is zhanggazi2008@gmail.com
zhanggazi
i read ur post regarding the properties of st cut quartz did u get them .if yes then can u send them to my email id rohankumar03@gmail.com..waiting for ur reply
Regards
rohan
Suggested Content
- BLOG Piezoelectric Materials: Understanding the Standards
- KNOWLEDGE BASE Resolving Time-Dependent Waves
- KNOWLEDGE BASE Error: Singular Matrix
- BLOG Piezoelectric Materials: Applying the Standards
- FORUM COMSOL AT CUT QUARTZ SIMULATION
