using stored solution in a matlab loop
Dear all
I am simulating a multiphysics problem which combines electric current with heat transfer, for multiple pulses .
I am trying to use a stored solution as an initial value for the proceeding MATLAB loops in order to see temperature accumulation. Is there a new command for using a stored solution in COMSOL 4.4? . I know there is an available command in COMSOL 3.5 "asseminit", is there a replacing command ?
Thanks for your help
1 Reply Last Post 22.06.2017, 09:32 GMT-4
Hello Nairouz Farah
Posted: 8 years ago 22.06.2017, 09:32 GMT-4
Dear all
have you been worked it out? I face a similar problem recently. I want to use solution from magnetic module as volume force in CFD module for several loops, since my current is pulse.
[QUOTE] Dear all I am simulating a multiphysics problem which combines electric current with heat transfer, for multiple pulses . I am trying to use a stored solution as an initial value for the proceeding MATLAB loops in order to see temperature accumulation. Is there a new command for using a stored solution in COMSOL 4.4? . I know there is an available command in COMSOL 3.5 "asseminit", is there a replacing command ? Thanks for your help [/QUOTE] Hi have you been worked it out? I face a similar problem recently. I want to use solution from magnetic module as volume force in CFD module for several loops, since my current is pulse.
