overlapping of two domains
I extruded an object to a distance of 0.2 microns. However when I add a block below it of height 1 microns I found that the two domains overlap each other. I want a structure such that the extruded object is on top of the block placed below it.I described the z-axis of the block below it to be -1 micron.Where am I doing the mistake?...please help
1 Reply Last Post 23.07.2015, 08:17 MESZ
Posted: 1 decade ago 23.07.2015, 08:17 MESZ
it's easier for us to understand if you provide a model file. one item could be the geometrical resolution you have by default that is not fine enough, depends on your model setting
Hi it's easier for us to understand if you provide a model file. one item could be the geometrical resolution you have by default that is not fine enough, depends on your model setting -- Good luck Ivar
