Meshing problem in two different sized objects
Posted 15.07.2015, 09:27 GMT-4 Version 4.3 2 Replies
Hi all,
I am trying to model micro-size spherical particles in a rectangular channel (both are 3D).
I am facing problem in meshing as the particles have diameter of 7 micrometer and the rectangular channel has length of 21 m.
Since there is a lot of difference in size between the two objects (particles and channel), so i am facing problem in meshing. I tried separate tetrahedral meshing on both bodies but it is not working and also triangular mesh on particle boundaries and then using tetrahedral meshing. but both approaches did not worked.
Kindly someone can help me on this issue?
Looking forward for your help
Thank You
Ali
Thank You
Ali
2 Replies Last Post 17.07.2015, 05:59 GMT-4
