select objects inside another
I am now working with the comsol 5.1. But in this version, I cannot select the objects inside another with multiple mouse click. Did any one come to the same problem?
Eric
2 Replies Last Post 08.07.2015, 04:15 GMT-4
Posted: 10 years ago 07.07.2015, 14:49 GMT-4
do the following:
in 3D view toolbar, click on Hide Geometric Entities
then select the domains that will you will hide in order to better view the inside objects.
Then you can easily select the inner objects.
do the following: in 3D view toolbar, click on Hide Geometric Entities then select the domains that will you will hide in order to better view the inside objects. Then you can easily select the inner objects.
Magnus Ringh COMSOL Employee
Posted: 10 years ago 08.07.2015, 04:15 GMT-4
You can also use the scroll wheel (mouse wheel) to select objects (domains, boundaries, etc.) that are inside of other objects. Scroll forward and backward to highlight all objects that you can "reach" from the cursor position. Another useful tool is the Selection List window, which provides a list of all boundaries, for example, in the geometry.
Magnus Ringh, COMSOL
Hi, You can also use the scroll wheel (mouse wheel) to select objects (domains, boundaries, etc.) that are inside of other objects. Scroll forward and backward to highlight all objects that you can "reach" from the cursor position. Another useful tool is the Selection List window, which provides a list of all boundaries, for example, in the geometry. Best regards, Magnus Ringh, COMSOL
