Interior port
Dear all thanks for your help in the beginning. I am simulating a problem of periodic nano-wires on silicon substrate and I want to calculate the spectral transmittance after the interface between the nano-wires and the substrate but when I put a port at this interface, I get the following error "The slit condition should be applied only on an interior boundary or the port should be placed on an exterior boundary.". How to solve this problem?
1 Reply Last Post 07.07.2015, 05:19 GMT-4
Posted: 10 years ago 07.07.2015, 05:19 GMT-4
While I am not sure if ports can indeed be placed on interiror boundaries, I will suggest you to simply compute the power flux through the interface you are interested in. It is the same as abs(emw.s21)^2
