Expression Syntax Error
How do I change the x-axis of a plot using a specific range of values? For example, I'd like to plot temperature as a function of distance and I'd like to vary the distance. How do I write this expression?
Something like range (0,0.01,d) would work? Considering the variable d previously defined.
I need some suggestions of which syntax I should use in this case.
Thank you!
1 Reply Last Post 24.06.2015, 02:03 GMT-4
Posted: 9 years ago 24.06.2015, 02:03 GMT-4
In the plot window there are options of the scaling, color, etc. There you can define scales, but if you wish to have ticks at certain intervals, I have not found a way of doing it in Comsol.
