parametric sweep to trace a particular solution?
Posted 10.06.2015, 05:22 GMT-4 RF & Microwave Engineering Version 5.1 0 Replies
I was wondering if there is a smarter way to do it? If, for instance, I use Livelink for Matlab, at each step of the parametric sweep I can update the trial eigenvalue (i.e. "Search for mode around.." field in the study options). This still does not help, however. Ideally, I need to feed each time not only the eigenvalue, but also the eigenvector from the previous step. I found some study options like "Initial values of variables solved for"... but I am not sure if this is what I need and how to use it properly.
Any advise would be highly appreciated!
PS I am using the "Wave optics" module, for some reason the corresponding tag is missing here. But RF module is similar anyway
Hello Andriy Gorbach
