How could I calculate the each element center of mass?
Hi!
I want to extract the value of each element center of mass.
it can be calculated using MATLAB, but I need it in COMSOL interface.
is it possible to extract the coordinate of center of mass in COMSOL?
not geometry !! each mesh element !
5 Replies Last Post 05.08.2010, 04:29 GMT-4
Posted: 1 decade ago 04.08.2010, 05:39 GMT-4
what about defining a integration coupling variable such that you get the CoG, you can also calculate the inertia tensor that way.
You then select the items you want to include and off you go
there are som tricks to use domain id via the bolean (dom==dest(dom)) and you define the destinatio items separately to get individual volumes, CoGs per item and not of all the selected items
Hi what about defining a integration coupling variable such that you get the CoG, you can also calculate the inertia tensor that way. You then select the items you want to include and off you go there are som tricks to use domain id via the bolean (dom==dest(dom)) and you define the destinatio items separately to get individual volumes, CoGs per item and not of all the selected items -- Good luck Ivar
Posted: 1 decade ago 04.08.2010, 06:34 GMT-4
thanks Ivar.
but I don't understand (dom==dest(dom)) expression.
What's that?
is it possible that expression in COMSOL? not Script?
thanks Ivar. but I don't understand (dom==dest(dom)) expression. What's that? is it possible that expression in COMSOL? not Script?
Posted: 1 decade ago 04.08.2010, 07:32 GMT-4
"dom" is the internal COMSOl variable equal to the domain id number (check the doc)
"dest()" is an internal COMSOL operator indicating that the integration coupling operator should use the destination domain (and not the default "source" domain where to get the information (again, check the doc)
"dest(dom))" is therefore the doman id of the "destination" part of the coupling integration variable operation
" == " is the bolean operation is equal resulting in an evaluation of 0 if false, 1 if true
therefore "(dom==dest(dom))" is equal to "1" if the source and destination domains are the same, i.e. have the same id, and is "0" elsewise
You must engage the "source" and "destination" lists/tabs of the integration coupling vaiable definition and select all destination domains of interest
Therefore, if you integrate over a domain the value "int1=(dom==dest(dom))*1" this would give you the volume of each domain (that is "int1" would have a different value, corresponding to the volume, for each separate domain).
As well as "mass_int1=(dom==dest(dom))*rho_smsld" (in V3.5a_smsld mode, or "mass_int1=(dom==dest(dom))*solid.rho" in V4 solid structural mode) would give you the total mass of each individual item
Knowing that the CoG is the integration over a domain of the vector "(x,y,z)*rho*dx*dy*dz" divided by the total mass of the domain (i.e. integration over the domain of "1*rho*dx*dy*dz") you should have everything to do the job, domain item by domain item (if you premultiply by the (dom==...), or as a global system.
try it out on a few cubes or spheres or circles of known radius, COMSOl is first of all a good math and geometry tool
Hi "dom" is the internal COMSOl variable equal to the domain id number (check the doc) "dest()" is an internal COMSOL operator indicating that the integration coupling operator should use the destination domain (and not the default "source" domain where to get the information (again, check the doc) "dest(dom))" is therefore the doman id of the "destination" part of the coupling integration variable operation " == " is the bolean operation is equal resulting in an evaluation of 0 if false, 1 if true therefore "(dom==dest(dom))" is equal to "1" if the source and destination domains are the same, i.e. have the same id, and is "0" elsewise You must engage the "source" and "destination" lists/tabs of the integration coupling vaiable definition and select all destination domains of interest Therefore, if you integrate over a domain the value "int1=(dom==dest(dom))*1" this would give you the volume of each domain (that is "int1" would have a different value, corresponding to the volume, for each separate domain). As well as "mass_int1=(dom==dest(dom))*rho_smsld" (in V3.5a_smsld mode, or "mass_int1=(dom==dest(dom))*solid.rho" in V4 solid structural mode) would give you the total mass of each individual item Knowing that the CoG is the integration over a domain of the vector "(x,y,z)*rho*dx*dy*dz" divided by the total mass of the domain (i.e. integration over the domain of "1*rho*dx*dy*dz") you should have everything to do the job, domain item by domain item (if you premultiply by the (dom==...), or as a global system. try it out on a few cubes or spheres or circles of known radius, COMSOl is first of all a good math and geometry tool -- Good luck Ivar
Posted: 1 decade ago 05.08.2010, 01:36 GMT-4
thanks! Ivar.
appreciate your answer.
but my question is how calculate center of element in COMSOL interface.
I think your answer is domain's CoG.
It is hard to extract CoG in COMSOL.
anyway,,, Thanks for trying to help.
have a nice day. Ivar.
thanks! Ivar. appreciate your answer. but my question is how calculate center of element in COMSOL interface. I think your answer is domain's CoG. It is hard to extract CoG in COMSOL. anyway,,, Thanks for trying to help. have a nice day. Ivar.
Posted: 1 decade ago 05.08.2010, 04:29 GMT-4
Indeed I was thinking of the physical centre or the CoG taking into account the density rho. But if you are looking for
the geometrical centre you use the integration over the volume with rho=1, no ?
With COMSOL you apply directly your integration eqautions on the geometry, it's not really complicated or ?
Hi Indeed I was thinking of the physical centre or the CoG taking into account the density rho. But if you are looking for the geometrical centre you use the integration over the volume with rho=1, no ? With COMSOL you apply directly your integration eqautions on the geometry, it's not really complicated or ? -- Good luck Ivar
