TM wave generation
Hi all,
I would like to generate a TM wave in a volume. Imagine a rectangle box which it's top surface emits an electric field with a determinate frequency. Somewhere in this rectangle box there is an object which interferes with this electric field.
How can I generate this type of wave?
I've tried using PML around the box and a scattering boundary condition with and incident electric field of E0z=1 on the top surface. But it doesn't seem to work.
Can anybody give me a hand with that?
Thanks & have fun!
3 Replies Last Post 22.07.2010, 06:52 GMT-4
Posted: 1 decade ago 22.07.2010, 03:06 GMT-4
I would start looking at the Floquet periodic boundary conditions
Hi I would start looking at the Floquet periodic boundary conditions -- Good luck Ivar
Posted: 1 decade ago 22.07.2010, 05:24 GMT-4
Hi Ivar,
Thanks for your answer.
From de doc I found this: "Floquet periodicity—There is a phase shift between the tangential components. The phase shift is determined by a wave vector and the distance between the source and destination. Floquet periodicity is typically used for models involving plane waves interacting with periodic structures."
But my model doesn't have a periodic structure. I want to simulate the effects produced on a charged structure due to the influence of an electric field
Any other tips that I can use?
Have fun comsoling!
Hi Ivar, Thanks for your answer. From de doc I found this: "Floquet periodicity—There is a phase shift between the tangential components. The phase shift is determined by a wave vector and the distance between the source and destination. Floquet periodicity is typically used for models involving plane waves interacting with periodic structures." But my model doesn't have a periodic structure. I want to simulate the effects produced on a charged structure due to the influence of an electric field Any other tips that I can use? Have fun comsoling!
Posted: 1 decade ago 22.07.2010, 06:52 GMT-4
I agree, partly, as 0 phase difference remains for me a Floquet, but that's a definition issue and can be discussed. Personally, I use them also for non periodic wave interaction, for me it remains a useful way to get 3D plane waves in a limited volume with or without periodic structures to be studied
Hi I agree, partly, as 0 phase difference remains for me a Floquet, but that's a definition issue and can be discussed. Personally, I use them also for non periodic wave interaction, for me it remains a useful way to get 3D plane waves in a limited volume with or without periodic structures to be studied -- Good luck Ivar
