How to change axis grid spacing
hello everyone, I would like to know how to change the grid spacing on the axis. By default Comsol draws the lines depending on the model dimension, i would like to fix this spacing. Is it possible?
2 Replies Last Post 15.05.2015, 11:57 GMT-4
Posted: 10 years ago 12.05.2015, 08:42 GMT-4
In 2D, yes, through Component>Definitions>View>Axis.
In 3D, not current: you can only turn the display of the axes on or off under Component>Definitions>View
In 2D, yes, through Component>Definitions>View>Axis. In 3D, not current: you can only turn the display of the axes on or off under Component>Definitions>View Best, Jeff
Posted: 10 years ago 15.05.2015, 11:57 GMT-4
ok, thanks for the answer
