Defining transmissivity
Farhad Kazemi Khosroshahi
I am trying to model radiative heat transfer in 3 parallel plates. the plates at the right and left sides are opaque and have only emissivity. but the plate at the center is transparrent (glass) how can I define this transparent material?
1 Reply Last Post 24.04.2015, 15:19 GMT-4
Walter Frei COMSOL Employee
Posted: 10 years ago 24.04.2015, 15:19 GMT-4
You will find this example:
www.comsol.com/model/radiative-cooling-of-a-glass-plate-19693
relevant if you want to consider radiative heat transfer inside of a glass plate.
Note that this example does require the Heat Transfer Module.
Hello, You will find this example: http://www.comsol.com/model/radiative-cooling-of-a-glass-plate-19693 relevant if you want to consider radiative heat transfer inside of a glass plate. Note that this example does require the Heat Transfer Module.
