need help on how to input the syntacs
Posted 28.06.2010, 01:14 GMT-4 3 Replies
Hello everyone.
I am a newbie on using COMSOL.
I would like to ask from someone who knows how to input the syntacs a command in COMSOL 3.5.
Right at the moment i am doing a study diffusion of moisture into a semi porous solid media and based on my literature reviews the diffusion coefficient of this semi porous solid media is dependent on temperature.
i have tried inputting the equation
Deff = 9.60 exp(-(4109.6/273+C))
It is the Deff that i would like to input as a function of Tenperature in Celsius represented by the variable C.
but an error occurs that tells me below as
Exception:
com.femlab.util.FlException: Syntax error in expression
- Expression: -9.60exp(-(4109.6/273+C)
- Variable: D_c_di
- Description: Diffusion coefficient c
- Subdomain: [1]
what i would like to ask if somebody could help me out how to input the syntax of this equation into the diffusion coefficient.
Thank you so much in advance for reading and the help extended.
god bless you.
Jonathan
Exception:
- Variable: D_c_di
- Subdomain: [1]
god bless you.
Jonathan
3 Replies Last Post 10.07.2010, 11:33 GMT-4
