24.06.2010, 13:34 MESZ
you can alsways define variables such as rxy = sqrt(x^2 +y^2) etc, or the full spherical definition and use thses for your functions, while leaving the model in cartesian corrdinates.
There are the full function set I believe on the knowledge base, search for "cylindical" or "spherical"
The basis for COMSOL (and it's strength) is that you can repleace each filed with a number by an equation, based on constants, or even other variables (up to the extent that you avoid loops, and make your system so non-linear that the solver does not manage to solve it anymore ;)
Have fun Comsoling
Have fun Comsoling
24.06.2010, 15:53 MESZ
Hi Ivar,
Thanks a lot, with the scalar expressions for r (sqrt(x^2+y^2)) and phi (atan2(y,x)) an projection coupling variable is possible.
Except the origin prepares some problems, because the divison by 2*r*pi in order to get the radial probability distribution diverges. But that is a smaller problem.
Thanks again,
Fabian
Hi Ivar,
Thanks again,
Fabian
24.06.2010, 16:06 MESZ
then try a if(r==0,0,your_fun(r)) or whatever it's called again in Comsol, check the doc, (I'm mixing to many software and get confused, but the idea works) you can use the bolean operators easily in postprocessing to get rid of singularities (its more tricky for dependent variables as this sometimes makes the solver having trouble)
have fun Comsoling
have fun Comsoling
