23.06.2010, 12:53 GMT-4
Usually if you do not attach your structure (at all) you get 6 frequencies at 0Hz (when in 3D) corresponding to the 6 free DOF.
Now if you model has a symmetry, such as an axial cylindrical symmetry (let say along Z), you might have a frequency bending along X, and one along Y, but as you model is symmetric you should see the same (or almost) frequency value for both so there is free variable along Rx and Ry. It's the degeneracy of the mode.
If you have no symmetry and your model is well fixed they should all be different. This is eneral physics and has nothing to do with COMSOL or A, or F or N or whatever the FEM software name is ?
Have fun Comsoling
Have fun Comsoling
11.08.2010, 18:32 GMT-4
I am doing eigenfrequency analysis of a Pratt truss bridge, similar to the example in the COMSOL documentation. However, the solution outputs 30 eigenfrequencies between 0 and 4 Hz, or 20 between 6 and 7 Hz. In many of these, just one or two structural elements are distorted when plotted. In other words, over half the eigen-functions appear to be garbage. Is this natural? Is their some way to filter these out, like putting a quality factor on the mode, or something like that?
Thanks.
Thanks.
12.08.2010, 03:18 GMT-4
It does not sound "normal" for me, I would say check your BC's again, you might have missed a power of ten somewhere in the materials, or something in the truss dimensions
sometimes a reset model and solve helps if you have edited a lot the file
